Lint filter clogged and blocked
  1. Lint filter clogged and blocked, Lint filter blocked: step 1, image 1 of 3 Lint filter clogged and blocked, Lint filter blocked: step 1, image 2 of 3 Lint filter clogged and blocked, Lint filter blocked: step 1, image 3 of 3
    • Open the access panel to the lint filter and remove it by carefully pulling it to the side.
  2. Lint filter clogged and blocked: step 2, image 1 of 2 Lint filter clogged and blocked: step 2, image 2 of 2
    • Remove the plug from the drain hose and drain the residual water into the bucket or collection tray that needs to be available.
  3. Lint filter clogged and blocked: step 3, image 1 of 2 Lint filter clogged and blocked: step 3, image 2 of 2
    • Check that the spare part sieve fits. Position the drill on one of the crescent-shaped recesses of the lint filter cover and place the hole close to the hole. Once all possible holes have been drilled all around, you can use the drill to cut through the remaining webs between the holes. Use the side of the drill as a cutter.
  4. Lint filter clogged and blocked: step 4, image 1 of 2 Lint filter clogged and blocked: step 4, image 2 of 2
    • It may be sufficient to drill out one side and remove the drilled-out part in order to be able to remove the debris from the sieve.
  5. Lint filter clogged and blocked: step 5, image 1 of 2 Lint filter clogged and blocked: step 5, image 2 of 2
    • Use some sturdy wire to bend a hook with which to remove the blocking material.
  6. Lint filter clogged and blocked: step 6, image 1 of 3 Lint filter clogged and blocked: step 6, image 2 of 3 Lint filter clogged and blocked: step 6, image 3 of 3
    • here is the removed material. Now the lint filter can be removed again and replaced with the spare part.
    • Attention: In the future, empty all trouser and jacket pockets before washing!
Screw in replacement lint filter
Special thanks to these translators:
de en
100%
oldturkey03 is helping us fix the world! Want to contribute?
Start translating ›
Martin Knaus
133 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 11
Past 30 Days: 57
All Time: 655
