Introduction
If your car phone holder is no longer gripping your phone securely—due to loose, jammed, or uneven closing wings—use this guide to diagnose and repair the internal spring and wing mechanism.
Car phone holders (also called car mounts, dashboard phone mounts, or air-vent phone holders) secure your smartphone in place while driving, allowing for hands-free navigation, calls, and media use. They rely on a spring-loaded plastic wing system to clamp onto devices. When the internal spring shifts out of place or the internal gears become misaligned, one or both arms may fail to close properly, causing the phone to slip or fall during driving.
Common symptoms of this issue include:
- One arm closing fully while the other remains stuck open
- Weak grip on the phone
- Clicking sounds without movement
- The mount failing to return to its closed position
These symptoms are typically caused by a dislodged suspension spring or misaligned internal gears, which this guide will help you fix.
Before starting this repair, remove the phone holder from your vehicle. This guide involves disassembling small mechanical parts and realigning a spring. Basic mechanical patience and steady hands are recommended.
Take your broken phone holder and flip it over.
Remove the back attachment by gently tugging downwards.
2 other people completed this guide.
