Fixing Rockwheel Electric Unicycle Balance Issues
  1. Fixing Rockwheel Electric Unicycle Balance Issues, Fixing Rockwheel Electric Unicycle Balance Issues: step 1, image 1 of 1
    • open the right side of the Rockwheel's case, the side of the power switch. To access the screws, you need to pull the glued rubber protection a little. Once the case is open you'll see the PCB, the motherboard. You'll need to insert a jumper wire in two right holes on the bottom of the PCB.
    • Once the trip wire installed, simply switch on the Rockwheel. Be careful, it is very loud!
    • Wait for one long beep, 4 short beeps, and one long beep again. Then switch off the Rockwheel, remove the jumper wire, close the case, and you're done.
6 other people completed this guide.
philippe
289 Reputation
1 Guide authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 1,738
