Fix Broken Dishes using Warm Milk
  1. Fix Broken Dishes using Warm Milk, Fix Broken Dishes using Warm Milk: step 1, image 1 of 1
    • Get ready to fix broken dishes.
  2. Fix Broken Dishes using Warm Milk: step 2, image 1 of 1
    • Prepare the tape. (You are going to use the tape to hold broken pieces together temporarily.)
  3. Fix Broken Dishes using Warm Milk: step 3, image 1 of 2 Fix Broken Dishes using Warm Milk: step 3, image 2 of 2
    • Put the plate back together and tape the broken pieces into place.
    • Be sure not to leave too large of gaps between the pieces so that the milk is able to bind the two surfaces together.
  4. Fix Broken Dishes using Warm Milk: step 4, image 1 of 1
    • Pour a generous amount of milk into a pot large enough to fit the entire dish being repaired.
    • The entire dish will need to be submerged for this to work, so test out if the dish can fit completely within the pot before you boil the milk.
    • Then heat the milk until it is near boiling.
  5. Fix Broken Dishes using Warm Milk: step 5, image 1 of 1
    • Gently submerge the broken dish completely in the hot milk.
  6. Fix Broken Dishes using Warm Milk: step 6, image 1 of 1
    • Leave the broken dish inside of the pot for 48 hours.
  7. Fix Broken Dishes using Warm Milk: step 7, image 1 of 1
    • Take out the broken dish from the pot.
    • Remove the tape from the dish.
  8. Fix Broken Dishes using Warm Milk: step 8, image 1 of 1
    • Check that the broken pieces now hold together on their own. If some of the pieces are still not connected, you may have to try again.
Without using a chemical glue, your broken piece should be attached to original dishes.
Juhwan Kim
181 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 33
All Time: 7,230
