Beaded Bracelet Clasp Replacement
  1. Beaded Bracelet Clasp Replacement, Beaded Bracelet Clasp: step 1, image 1 of 1
    • From the left end of the bracelet, string on a crimp bead and one end of the new clasp.
    • Bring the clasp and crimp bead 3 inches from the left end of the string.
  2. Beaded Bracelet Clasp Replacement: step 2, image 1 of 1
    • Loop the left end of the string through the left side of the crimp bead.
  3. Beaded Bracelet Clasp Replacement: step 3, image 1 of 1
    • Push the crimp bead up close to the clasp.
    • Push the crimp bead up as close as you can to the clasp.
  4. Beaded Bracelet Clasp Replacement: step 4, image 1 of 2 Beaded Bracelet Clasp Replacement: step 4, image 2 of 2
    • Use the bead crimp tool to squeeze the crimp bead shut.
    • Use scissors to cut off excess string.
  5. Beaded Bracelet Clasp Replacement: step 5, image 1 of 1
    • Bead the bracelet from the right end.
  6. Beaded Bracelet Clasp Replacement: step 6, image 1 of 1
    • After all beads are on, string on a crimp bead and then the other end of the new clasp.
  7. Beaded Bracelet Clasp Replacement: step 7, image 1 of 1
    • Loop the right end of the string through the right side of the crimp bead.
  8. Beaded Bracelet Clasp Replacement: step 8, image 1 of 1
    • Pull on the string to tighten the bracelet.
    • You do not want the beads spread out.
  9. Beaded Bracelet Clasp Replacement: step 9, image 1 of 2 Beaded Bracelet Clasp Replacement: step 9, image 2 of 2
2 other people completed this guide.
Kelly
182 Reputation
1 Guide authored
2 Comments
Awesome!! Its very beautiful [|bracelets] each step make this bracelets so easy. Thank you!! Keep it up
daniel - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 32
All Time: 2,371
