Shop the Holiday Gift Guide
Fairphone Fairbuds Mainboard Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
27
Past 30 Days:
150
All Time:
2,090
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Use this guide to replace the mainboard in your Fairphone Fairbuds.
You should replace your mainboard if your charging case isn't working, and you've ruled out any issues with the charging case's battery.
Tools
  • Phillips #00 Screwdriver
    4.9
  • Spudger
    4.9
    1. Fairphone Fairbuds Mainboard Replacement, Remove the earbuds: step 1, image 1 of 2 Fairphone Fairbuds Mainboard Replacement, Remove the earbuds: step 1, image 2 of 2
      • Remove your earbuds from the charging case.
      Ask FixBot
    1. Fairphone Fairbuds Mainboard Replacement, Remove the outer shell screw: step 2, image 1 of 2 Fairphone Fairbuds Mainboard Replacement, Remove the outer shell screw: step 2, image 2 of 2
      • Flip your charging case upside down.
      • Use a Phillips screwdriver to remove the 4.5 mm‑long screw securing the outer shell.
      Ask FixBot
    2. Fairphone Fairbuds Mainboard Replacement, Remove the battery: step 3, image 1 of 2 Fairphone Fairbuds Mainboard Replacement, Remove the battery: step 3, image 2 of 2
      • Flip up the bottom of the outer shell to expose the battery.
      Ask FixBot
    3. Fairphone Fairbuds Mainboard Replacement: step 4, image 1 of 3 Fairphone Fairbuds Mainboard Replacement: step 4, image 2 of 3 Fairphone Fairbuds Mainboard Replacement: step 4, image 3 of 3
      • Use your finger to pry up the battery at its notch and remove it.
      Ask FixBot
    1. Fairphone Fairbuds Mainboard Replacement, Remove the charging core: step 5, image 1 of 2 Fairphone Fairbuds Mainboard Replacement, Remove the charging core: step 5, image 2 of 2
      • Lift the charging core out of the outer shell and remove it.
      Ask FixBot
    1. Fairphone Fairbuds Mainboard Replacement, Remove the charging core screws: step 6, image 1 of 2 Fairphone Fairbuds Mainboard Replacement, Remove the charging core screws: step 6, image 2 of 2
      • Use a Phillips screwdriver to remove the six 3.9 mm‑long screws securing the two halves of the charging core.
      Ask FixBot
    2. Fairphone Fairbuds Mainboard Replacement, Open the charging core: step 7, image 1 of 3 Fairphone Fairbuds Mainboard Replacement, Open the charging core: step 7, image 2 of 3 Fairphone Fairbuds Mainboard Replacement, Open the charging core: step 7, image 3 of 3
      • Flip over the charging core and grip its top half, near the pairing button.
      • Lift the top half and swing it over the core, letting it rest on something sturdy.
      • Don't try to separate the two halves, as they're still attached by cables.
      Ask FixBot
    3. Fairphone Fairbuds Mainboard Replacement, Disconnect the mainboard: step 8, image 1 of 3 Fairphone Fairbuds Mainboard Replacement, Disconnect the mainboard: step 8, image 2 of 3 Fairphone Fairbuds Mainboard Replacement, Disconnect the mainboard: step 8, image 3 of 3
      • Use your fingers to pull the left earbud charging cable out of its socket.
      • Don't grip the cable! Only pull on the cable's plastic head.
      • If you're having trouble gripping the cable's head, use the tip of a spudger to push it out of its socket.
      Ask FixBot
    4. Fairphone Fairbuds Mainboard Replacement: step 9, image 1 of 3 Fairphone Fairbuds Mainboard Replacement: step 9, image 2 of 3 Fairphone Fairbuds Mainboard Replacement: step 9, image 3 of 3
      • Since the remaining connectors are next to each other, it can be difficult to grip them with your fingers. The following instructions use a spudger instead.
      • Use the tip of a spudger to push the right earbud cable head out of its socket to disconnect it.
      • Repeat for the USB-C port cable.
      Ask FixBot
    5. Fairphone Fairbuds Mainboard Replacement, Remove the mainboard screws: step 10, image 1 of 2 Fairphone Fairbuds Mainboard Replacement, Remove the mainboard screws: step 10, image 2 of 2
      • Use a Phillips screwdriver to remove the two 3.9 mm‑long screws securing the mainboard.
      Ask FixBot
    6. Fairphone Fairbuds Mainboard Replacement, Remove the mainboard: step 11, image 1 of 3 Fairphone Fairbuds Mainboard Replacement, Remove the mainboard: step 11, image 2 of 3 Fairphone Fairbuds Mainboard Replacement, Remove the mainboard: step 11, image 3 of 3
      • Lift the mainboard off its posts in the charging core and remove it.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
2 other people completed this guide.
Author
with
Alex Diaz-Kokaisl
252,372 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,190 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 27
Past 30 Days: 150
All Time: 2,090
