Shop the Holiday Gift Guide
Fairphone Fairbuds Earbud Battery Replacement
Views: 9.5K
View statistics:
Past 24 Hours:
20
Past 7 Days:
101
Past 30 Days:
507
All Time:
9,539
Comments: 1
1 guide comment.
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 - 10 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace the earbud battery in your Fairphone Fairbuds.
While the earbud battery is classified as a LIR1054 3.6V rechargeable lithium-ion battery, it's a different shape than similar batteries you can source at a store. You can buy them from Fairphone here.
Parts
Tools
  • Spudger
    4.9
  • Tweezers
    Optional
    1. Fairphone Fairbuds Earbud Battery Replacement, Remove the earbuds: step 1, image 1 of 2 Fairphone Fairbuds Earbud Battery Replacement, Remove the earbuds: step 1, image 2 of 2
      • Remove your earbuds from the charging case.
      Ask FixBot
    1. Fairphone Fairbuds Earbud Battery Replacement, Remove the silicone ring: step 2, image 1 of 3 Fairphone Fairbuds Earbud Battery Replacement, Remove the silicone ring: step 2, image 2 of 3 Fairphone Fairbuds Earbud Battery Replacement, Remove the silicone ring: step 2, image 3 of 3
      • Use your fingers or tweezers to pull the silicone ring off its groove in the earbud.
      • If you're reusing the silicone ring, don't stretch it too far or it won't fit snug in its groove.
      • Remove the silicone ring.
      • During reassembly, align the tab on the silicone ring with the notch on the earbud to ensure the ring fits snug.
      Ask FixBot
    1. Fairphone Fairbuds Earbud Battery Replacement, Remove the battery: step 3, image 1 of 3 Fairphone Fairbuds Earbud Battery Replacement, Remove the battery: step 3, image 2 of 3 Fairphone Fairbuds Earbud Battery Replacement, Remove the battery: step 3, image 3 of 3
      • Insert the pointed end of a spudger into the notch on the battery tray, above the plus and minus sign.
      • Pry up to unlatch the battery tray from the earbud.
      Ask FixBot
    2. Fairphone Fairbuds Earbud Battery Replacement: step 4, image 1 of 3 Fairphone Fairbuds Earbud Battery Replacement: step 4, image 2 of 3 Fairphone Fairbuds Earbud Battery Replacement: step 4, image 3 of 3
      • Swing open the battery tray and remove the battery.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
2 other people completed this guide.
Author
with
Alex Diaz-Kokaisl
252,752 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,189 Guides authored
1 Guide Comment
Are these going to be available in the USA? If so are the battery replacements going to be available in the USA?
I wish a company would make some non-ANC airpod type headphones that use standard hearing aid batteries i can buy at the grocery store.
Zak Whipp - Reply Share
Past 24 Hours: 20
Past 7 Days: 101
Past 30 Days: 507
All Time: 9,539
