Shop the Holiday Gift Guide
Fairphone Fairbuds Charging Case Battery Replacement
Views: 2.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
36
Past 30 Days:
175
All Time:
2,717
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 minutes
Difficulty: Easy
Featured Guide
This guide has been found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Use this guide to replace a damaged or worn-out charging case battery in your Fairphone Fairbuds.
You can buy a replacement charging case battery from Fairphone here.
Parts
Tools
    1. Fairphone Fairbuds Charging Case Battery Replacement, Remove the outer shell screw: step 1, image 1 of 2 Fairphone Fairbuds Charging Case Battery Replacement, Remove the outer shell screw: step 1, image 2 of 2
      • Flip your charging case upside down.
      • Use a Phillips screwdriver to remove the 4.5 mm‑long screw securing the outer shell.
      Ask FixBot
    2. Fairphone Fairbuds Charging Case Battery Replacement, Remove the battery: step 2, image 1 of 2 Fairphone Fairbuds Charging Case Battery Replacement, Remove the battery: step 2, image 2 of 2
      • Flip up the bottom of the outer shell to expose the battery.
      Ask FixBot
    3. Fairphone Fairbuds Charging Case Battery Replacement: step 3, image 1 of 3 Fairphone Fairbuds Charging Case Battery Replacement: step 3, image 2 of 3 Fairphone Fairbuds Charging Case Battery Replacement: step 3, image 3 of 3
      • Use your finger to pry up the battery at its notch and remove it.
      Ask FixBot
For optimal performance, calibrate your newly installed battery after completing this guide.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
Alex Diaz-Kokaisl
252,372 Reputation
1,200 Guides authored
Guide Team Member of Guide Team
Staff
10 Members
62,190 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 36
Past 30 Days: 175
All Time: 2,717
