Fairphone 3 Battery Replacement
  1. Fairphone 3 Battery Replacement, Back Cover: step 1, image 1 of 2 Fairphone 3 Battery Replacement, Back Cover: step 1, image 2 of 2
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom right of the back cover.
    • Pry the back cover up to start separating its plastic clips.
  2. Fairphone 3 Battery Replacement: step 2, image 1 of 3 Fairphone 3 Battery Replacement: step 2, image 2 of 3 Fairphone 3 Battery Replacement: step 2, image 3 of 3
    • Slide around the bottom right corner of the back cover to loosen the lower plastic clips.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • To reinstall the back cover press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. Fairphone 3 Battery Replacement, Battery: step 3, image 1 of 2 Fairphone 3 Battery Replacement, Battery: step 3, image 2 of 2
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    • Lever the battery up until you can get a good grip.
  4. Fairphone 3 Battery Replacement: step 4, image 1 of 2 Fairphone 3 Battery Replacement: step 4, image 2 of 2
    • Lift the battery out of its recess and remove it.
Dominik Schnabelrauch
202,558 Reputation
682 Guides authored
iFixit Member of iFixit
Staff
135 Members
16,718 Guides authored
Past 24 Hours: 4
Past 7 Days: 37
Past 30 Days: 136
All Time: 8,017
