Introduction
Replacing the battery in your Fairphone 2 is easy and requires no tools.
Pick a corner of your slim case and get between the two parts with your thumb's fingernails.
Pull up the back part of the slim case to separate the small snap fit connections.
Remove the back part of the slim case.
Push the battery toward the top of the phone.
Pull the battery out away from the phone.
It isn't necessary to remove the rim if all you are doing is changing the battery. That becomes necessary if you are to proceed farther into the phone.
It might be good to begin by saying switch the phone off. The Fairphone is for everybody and most will have no experience of disassembling electronic devices.
9 other people completed this guide.
One Comment
It's not necessary to remove the rim unless you are to do more than just replace the battery.
It would be good to start by saying, “Switch off the phone,” as most owners won't be accustomed to disassembling electronic devices.
