Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors
View statistics:
Past 24 Hours:
2
Past 7 Days:
25
Past 30 Days:
120
All Time:
320
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
    1. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors, Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 1, image 1 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors, Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 1, image 2 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors, Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 1, image 3 of 3
      • SACI industrial voltmeter, a Spanish brand; it has been in use for quite a few years and broke down by turning off. It was replaced with a new one from another manufacturer, but why not take a look and try to repair it as a challenge?
      Ask FixBot
    2. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 2, image 1 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 2, image 2 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 2, image 3 of 3
      • Disassembling it, I see that it is made up of 2 PCB boards stacked one on top of the other, the smaller board being the multi-voltage power input (very typical in the industrial field) and that the output is a symmetrical power supply of +12V, 0, -12V, so this voltage can be very easily simulated with 2 dead batteries and checked.
      • If the problem is only with the power input board or has also affected the measurement board, with the 2 dead batteries connected, the board turns on, so the problem is only with the power input board.
      • I see that it turns on with 12V and 0, but it needs the -12V to be able to stabilize the display so that it stays at 000.0V
      Ask FixBot
    3. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 3, image 1 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 3, image 2 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 3, image 3 of 3
      • Example: by removing the -12V voltage, the display does not stay at 000.0V
      • Photo 3: view from where I have taken the wiring to power it with external batteries to test the board.
      Ask FixBot
    4. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 4, image 1 of 2 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 4, image 2 of 2
      • View of the power input "backpack" board, which is causing the failure.
      Ask FixBot
    5. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 5, image 1 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 5, image 2 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 5, image 3 of 3
      • I desolder the board to perform measurements and be able to remove components from it. Measuring the capacitors directly on the PCB, 2 of them provide a measurement much lower than what they should be measuring; I remove them from the PCB to measure them outside.
      Ask FixBot
    6. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 6, image 1 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 6, image 2 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 6, image 3 of 3
      • The two capacitors measured off the PCB, rated at 470 µF/16 V, measure approximately 60.7 µF; they are completely low on capacitance.
      • I replace both and test the PCB by applying 230 V AC input voltage.
      Ask FixBot
    7. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 7, image 1 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 7, image 2 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 7, image 3 of 3
      • View of the 2 replaced capacitors; since I am using recycled material from other boards, I soldered one of them with 2 pieces of wire because its terminals were too short.
      Ask FixBot
    8. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 8, image 1 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 8, image 2 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 8, image 3 of 3
      • With the circuit powered at 230 V, it now has a +12 V, 0, -12 V voltage output.
      Ask FixBot
    9. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 9, image 1 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 9, image 2 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 9, image 3 of 3
      • Measured between +12 and -12 we have the nearly 24 V difference, so the backpack board can be soldered back onto the main board.
      Ask FixBot
    10. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 10, image 1 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 10, image 2 of 3 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 10, image 3 of 3
      • Mounting the backpack PCB onto the main PCB.
      Ask FixBot
    11. Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 11, image 1 of 2 Failure 1: SACI DP35CM Industrial Voltmeter 24/7 use Does not turn on, failure of 2 470 uF/16V capacitors: step 11, image 2 of 2
      • View of the voltmeter once repaired; having replaced the two 470 µF / 16 V capacitors, we once again have an industrial panel voltmeter for 24/7 use. This one was replaced by a new one, so now I have a functional spare.
      Ask FixBot
Finish Line
Carlos López (España - Spain)
108,686 Reputation
402 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 25
Past 30 Days: 120
All Time: 320
