FS-200 Impulse Heat Sealer Heating Element Replacement
  1. FS-200 Impulse Heat Sealer Heating Element Replacement, Heating Element: step 1, image 1 of 2 FS-200 Impulse Heat Sealer Heating Element Replacement, Heating Element: step 1, image 2 of 2
    • Unplug the heat sealer from any power source and make sure the heat sealer isn't hot.
    • Lift the sealing arm and position it up and out of the way to create space for the replacement.
  2. FS-200 Impulse Heat Sealer Heating Element Replacement: step 2, image 1 of 3 FS-200 Impulse Heat Sealer Heating Element Replacement: step 2, image 2 of 3 FS-200 Impulse Heat Sealer Heating Element Replacement: step 2, image 3 of 3
    • Using a standard Phillips #2 screwdriver, remove the first two screws to detach the first metal panel.
  3. FS-200 Impulse Heat Sealer Heating Element Replacement: step 3, image 1 of 2 FS-200 Impulse Heat Sealer Heating Element Replacement: step 3, image 2 of 2
    • Using a standard Phillips #2 screwdriver, unscrew the remaining two screws to remove the second metal panel.
  4. FS-200 Impulse Heat Sealer Heating Element Replacement: step 4, image 1 of 2 FS-200 Impulse Heat Sealer Heating Element Replacement: step 4, image 2 of 2
    • Remove the teflon strip to expose the heating element wire.
  5. FS-200 Impulse Heat Sealer Heating Element Replacement: step 5, image 1 of 3 FS-200 Impulse Heat Sealer Heating Element Replacement: step 5, image 2 of 3 FS-200 Impulse Heat Sealer Heating Element Replacement: step 5, image 3 of 3
    • Using a standard Phillips #2 screwdriver, unscrew the large single screw and remove the old heating element wire.
  6. FS-200 Impulse Heat Sealer Heating Element Replacement: step 6, image 1 of 3 FS-200 Impulse Heat Sealer Heating Element Replacement: step 6, image 2 of 3 FS-200 Impulse Heat Sealer Heating Element Replacement: step 6, image 3 of 3
    • Position the new heating element by placing one end of the wire onto the pin located beneath the arm lever.
  7. FS-200 Impulse Heat Sealer Heating Element Replacement: step 7, image 1 of 1
    • Stretch the wire across the base pulling it towards the corresponding screw hole. The pin from the first side will slide as you pull it tight.
    • Holding the heating element taught, line up the 2 holes and use a standard Phillips #2 screwdriver to screw in the large single screw.
AshleyDrake
145 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 65
All Time: 365
