Introduction
The batteries included in the packs are prone to failure and leaking. This guide will show you how to replace the batteries with better quality rechargeables.
Remove battery pack from the Wii Remote and locate the two screws between the batteries. Remove these and put them asside.
Re-insert the screws. The battery pack will only fit in one direction.
While you are at it, clean the outer contacts and bend them out a little. This can help eliminate remotes having poor battery life.
I would love to repair my RVL-003 controller but my battery pack has a different battery item #87048-E-14 top half of battery case is blue bottom half molded to back cover of controller is white have you ever changed out this type without destroying it? Can the battery case be split and change out batteries?
You should now have a working battery pack. Insert back into the Wii Remote and place on the charger. Allow it to get a good full initial charge in order to extend your battery life.
Enjoy your "non-reparable" repaired induction charging system.
8 other people completed this guide.
2 Comments
Wow, that explains it. So many complaints about the energizer inductive batteries dying quickly. They take a product meant for two AA and replace it with two AAA's. Yep, that'll limit your playing time...
Easy to do! Just waiting to see if it will charge. If not, it was worth the shot. Thank you!
