Ematic eGlide 4 Wi-Fi Adaptor Replacement
  1. Ematic eGlide 4 Wi-Fi Adaptor Replacement, Rear Panel: step 1, image 1 of 1
    • Remove the 4.6mm Phillips #00 screw at the base of the device.
  2. Ematic eGlide 4 Wi-Fi Adaptor Replacement: step 2, image 1 of 1
    • Slide the rear panel away from the base parallel to the screen.
  3. Ematic eGlide 4 Wi-Fi Adaptor Replacement: step 3, image 1 of 2 Ematic eGlide 4 Wi-Fi Adaptor Replacement: step 3, image 2 of 2
    • Carefully remove the speakers from the rear panel.
    • Pull the speakers off of the rear panel.
  4. Ematic eGlide 4 Wi-Fi Adaptor Replacement, Wi-Fi Adaptor: step 4, image 1 of 1
  5. Ematic eGlide 4 Wi-Fi Adaptor Replacement: step 5, image 1 of 1
    • Gently pry the antenna out of the front case
Bailey Hughes
617 Reputation
6 Guides authored
Baylor, Team 5-8, Williams Spring 2015 Member of Baylor, Team 5-8, Williams Spring 2015
BU-WILLIAMS-S15S5G8
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 108
