Introduction
Today the scales did not go anymore.
The display remained black.
So I had to find a way to disassemble.
Extra rausholen the Heißluftföhn and time consuming to heat the glass plate? It would have to be easier!
Tools
Parts
No parts required.
Since it is not important in the balance to get the adhesive surfaces take a beveled spatula. It's much easier and faster.
  • Since it is not important in the balance to get the adhesive surfaces take a beveled spatula. It's much easier and faster.
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
Contrary to the other instructions, the board is located directly on the plastic housing. Through the 3 holes water gets into the balance and through the adhesion it spreads over the complete underside of the board The Libra continues to change. Only this time too much water had penetrated which had spread under the board.
  • Contrary to the other instructions, the board is located directly on the plastic housing. Through the 3 holes water gets into the balance and through the adhesion it spreads over the complete underside of the board
  • The Libra continues to change. Only this time too much water had penetrated which had spread under the board.
  • Clean the underside of the board with acetone. Alternatively, isopropanol.
  • After the board was dry, the scales spoke to me again. And so that water does not penetrate again, I taped the holes with silicone
  • Finally, glue the round cap to the glass plate with a little silicone glue. Because even if the board has a silicone protective coating, it would not be good if Wassser came from above on the SMD components.
Repeat the steps in order to reassemble your device.
Special thanks to these translators:
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Marina
1 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 24
All Time: 156
