E46 M3 door card/panel removal
  1. E46 M3 door card/panel removal, Identify the screws: step 1, image 1 of 1
    • The door card is held securely in place with 5 screws.
    • Keep in mind the door card has up to 3 wire bundles attached to it. Be careful when removing it! Be prepared to support it while dealing with the wires.
  2. E46 M3 door card/panel removal, Remove screw covers: step 2, image 1 of 2 E46 M3 door card/panel removal, Remove screw covers: step 2, image 2 of 2
    • Using a spudger, work off the cap of the first screw. The cap is tight; you may need a jimmy or metal spudger.
    • Using the flat end of a spudger, remove the airbag emblem. The emblem has clips on the top and bottom -- work carefully.
  3. E46 M3 door card/panel removal, Remove bolts: step 3, image 1 of 1
    • Using a T20 Torx driver with extension, remove all 5 bolts.
  4. E46 M3 door card/panel removal, Remove mirror control: step 4, image 1 of 1
    • If you're working on the driver side door, remove the mirror control module. Disconnect it from its wiring plug.
  5. E46 M3 door card/panel removal, Pop door card clips: step 5, image 1 of 2 E46 M3 door card/panel removal, Pop door card clips: step 5, image 2 of 2
    • Using a trim tool or similar, begin at the bottom of the door card and pop the card away from the door frame.
    • After you've released the bottom clips, work your way around.
    • You will need to lift the door card from the door frame in order to fully release it. Be careful!
    • Disconnect the following from the door panel:
    • Unlocking cable
    • Speaker cable(s)
    • Set the door panel aside.
  6. E46 M3 door card/panel removal, Door panel removed!: step 7, image 1 of 1
    • The door panel is now removed.
    • You will see the airbag module, vapor barrier, and other components.
Dom Santangelo
592 Reputation
3 Guides authored
Past 24 Hours: 9
Past 7 Days: 39
Past 30 Days: 154
All Time: 14,802
