Disconnecting Dell Latitude 5320 2-in-1 Battery
  1. Disconnecting Dell Latitude 5320 2-in-1 Battery, Disconnecting Dell Latitude 5320 2-in-1 Battery: step 1, image 1 of 1
    • Shut down your laptop completely.
    • Unplug the laptop from any charging cables or other connected accessories.
    • Flip the laptop over so the bottom case is facing upward.
    Ask FixBot
  2. Disconnecting Dell Latitude 5320 2-in-1 Battery: step 2, image 1 of 2 Disconnecting Dell Latitude 5320 2-in-1 Battery: step 2, image 2 of 2
    • Using a Phillips #000 screwdriver, loosen the eight captive screws that secure the bottom cover.
    • The screws will remain attached to the cover, so do not try to remove them completely. Turn each screw until it spins freely and you feel it no longer tightens.
    Ask FixBot
  3. Disconnecting Dell Latitude 5320 2-in-1 Battery: step 3, image 1 of 3 Disconnecting Dell Latitude 5320 2-in-1 Battery: step 3, image 2 of 3 Disconnecting Dell Latitude 5320 2-in-1 Battery: step 3, image 3 of 3
    • Insert an opening tool into the seam between the bottom cover and the rest of the device.
    • Gently work your way around the edges until the clips release. Lift the cover away and set it aside.
    Ask FixBot
  4. Disconnecting Dell Latitude 5320 2-in-1 Battery: step 4, image 1 of 3 Disconnecting Dell Latitude 5320 2-in-1 Battery: step 4, image 2 of 3 Disconnecting Dell Latitude 5320 2-in-1 Battery: step 4, image 3 of 3
    • Gently lift the battery cable straight up from its socket on the motherboard to disconnect it.
    Ask FixBot
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 23
All Time: 159
