Introduction
This guide explains how to remove the outer case so that you can access the internal components of the Game Boy. This will be helpful for other guides related to this hand-held gaming console.
Switch your Game Boy off and remove the cartridge. Switch your Game Boy off and remove the cartridge.
  • Switch your Game Boy off and remove the cartridge.
Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door. The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle. When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
  • Use a fingernail (or small coin) to push down on the battery door latch and remove the battery door.
    • The release latch is a plastic spring clip. If your Game Boy is getting on in years, be careful as the plastic may be brittle.
    • When you're replacing the cover, be sure to get its two plastic tabs into the slots in the bottom of the battery compartment before pushing the cover back in place.
Use a fingernail to pry each battery outward from the positive (+) terminal to remove them. Dispose of used batteries properly!
  • Use a fingernail to pry each battery outward from the positive (+) terminal to remove them.
    • Dispose of used batteries properly!
    • Remove the batteries from your Game Boy before storing it for more than a month or so.
New Battery = Faster iPhone
Fix Kits starting at $16.99
Remove the six Triwing screws from the back of the device.
  • Remove the six Triwing screws from the back of the device.
Gently separate the device's front casing from the back casing after you remove the screws.
  • Gently separate the device's front casing from the back casing after you remove the screws.
    • Be careful not to completely separate the casing halves, as they are still joined by a large ribbon cable that may be damaged.
Slide the front side of the casing down to expose the ribbon cable connector.
  • Slide the front side of the casing down to expose the ribbon cable connector.
Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
  • Grip the ribbon connector with your thumb and forefinger. Pull down gently until the connector, not the ribbon itself, comes out of its socket.
  • Separate the front and back casings.
13 other people completed this guide.
Andrew Tramposch
1,484 Reputation
11 Guides authored
Cal Poly, Team 3-2, Johann Summer 2010 Member of Cal Poly, Team 3-2, Johann Summer 2010
CPSU-JOHANN-R10S3G2
3 Members
11 Guides authored
U need a tri-wing screwdriver not a Philips #00
radiofreeroyaloak - Reply
It is a Philips if gb was made after 1998 or so.
Sam - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 15,464
