WARNING! From this step we will void any warranty of your keyfob.
If you just needed to replace your battery, going forward is not neccessary. If you need to solder in a new button, the only possible way to do it, is to cut open the key. It will reassemble without issues later.
Be careful not to damage the grip tabs of the plastic cover that we removed earlier, while you carefully cut away the two long lighter color plastic tabs on both sides, using a sharp knife.
