Introduction
Removing the back panel from the Toshiba AT1304T
If you can't get a hold of a Torx 6 Security Screwdriver, a small flathead can be used as a substitute
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
If needed, use the flathead screwdriver to gently pry the panel from the phone.
Using your fingers, lift the panel from the device.
