Disassembling Speak And Spell Case
  1. Disassembling Speak And Spell Case, Case: step 1, image 1 of 2 Disassembling Speak And Spell Case, Case: step 1, image 2 of 2
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: step 2, image 1 of 1
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
bushing
10,250 Reputation
13 Guides authored
One Comment
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 4,960
