Introduction
Removing the housing to get to the components beneath.
Use the flat side of a metal spudger to peel the black rubber cover off of the casing.
Unscrew the four 16 mm long screws from the back panel with a T10 Torx Screwdriver.
Use a firm grip to peel off the back panel. It is sealed tight and requires a good amount of force to remove.
Pry apart the two halves of the housing at the back side of the driver using the metal spudger .
Pull out all electrical components from housing by hand. First, lift out the motor. Next, follow the wires, lifting out components until all components are outside of the housing.
