Disassembling RCA 22” DECK215R HDTV Stand and Back Panel
  1. Disassembling RCA 22” DECK215R HDTV Stand and Back Panel, Removing the Stand: step 1, image 1 of 2 Disassembling RCA 22” DECK215R HDTV Stand and Back Panel, Removing the Stand: step 1, image 2 of 2
    • Before disassembling your television, ensure that all cables are unplugged from their power source to avoid serious injury or death from electrocution.
    • Lay the TV flat with the screen facing down.
    • Remove the four, 12mm Phillips #2 screws from the back of the TV stand. Support the TV from underneath as you remove the screws, so the bottom does not fall on the table.
    • Remove the stand by lifting it away from the TV's backing.
  2. Disassembling RCA 22” DECK215R HDTV Stand and Back Panel, Removing the Back Panel: step 2, image 1 of 2 Disassembling RCA 22” DECK215R HDTV Stand and Back Panel, Removing the Back Panel: step 2, image 2 of 2
    • Remove the twelve, 6mm Phillips #2 screws from the middle of the TV's rear casing.
    • Remove the seven, 9mm Phillips #2 screws from the outer edge of the TV's rear casing.
    • While holding the screen down, pull the back panel up slowly, ensuring that you do not forcibly disconnect the remaining ribbon cable.
  3. Disassembling RCA 22” DECK215R HDTV Stand and Back Panel, Locate Pin: step 3, image 1 of 1
    • Position the television to where the back panel is resting on the table and the screen is vertical.
    • Peel the tape covering the ribbon cable horizontally.
  4. Disassembling RCA 22” DECK215R HDTV Stand and Back Panel: step 4, image 1 of 3 Disassembling RCA 22” DECK215R HDTV Stand and Back Panel: step 4, image 2 of 3 Disassembling RCA 22” DECK215R HDTV Stand and Back Panel: step 4, image 3 of 3
    • Pinch the clamps on both sides of the ribbon cable casing to detach it from the screen panel.
    • Remove the screen to isolate the back panel.
2 other people completed this guide.
Patrick Soper
691 Reputation
6 Guides authored
Cal Poly, Team 70-2, Forte Winter 2015 Member of Cal Poly, Team 70-2, Forte Winter 2015
CPSU-FORTE-W15S70G2
4 Members
10 Guides authored
8 Comments
essay about social media will be also interesting for you. In case if you like reading interesting short topics on different themes, you are welcomed to read or articles.
Cortez Baylor - Reply
Livin' in a world where no one's innocent Oh, but at least we try, mmm Gotta live my truth, not keep it bottled in So I don't lose my mind, baby, yeah
geometry dash
pkinpum - Reply
I've been utilizing essay writing services from essayreasures.com for four months now. Recommend them!
Tommy - Reply
Dude. Awesome vid! Thank you so much for this, you saved my tookus. I have the Trio Stealth G2 and the guts look EXACTLY the same as the RCA in your vid. Actually I have 2 and one of them (the one with the messed up power button, just like yours) is being used now for parts.Just swapped out the guts on the one with the cracked screen with the one with the bad power button. Only difference was they had glued the battery in instead of adhesive strips. Thanks again, you rock. Stickman Hook
Rose Watson - Reply
Are you a lover of finding and discovering new words?
If that's the case, then this Word Finder is a tool you just can't do without.
Anna Stark - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 1,980
