Disassembling Pentax PZ-10 Top Cover
  1. Disassembling Pentax PZ-10 Top Cover, Top Cover: step 1, image 1 of 1
    • The top cover is one piece encasing the top of the device except the shutter release button and flash.
  2. Disassembling Pentax PZ-10 Top Cover, Removing Upper Right Housing Screw: step 2, image 1 of 2 Disassembling Pentax PZ-10 Top Cover, Removing Upper Right Housing Screw: step 2, image 2 of 2
    • With the camera lens face down, locate the screw under the overhanging piece of the top casing on the right side of the back panel.
    • Using the J0 screwdriver, remove the 6.3 mm screw.
  3. Disassembling Pentax PZ-10 Top Cover, Removing Screw in Battery Compartment: step 3, image 1 of 2 Disassembling Pentax PZ-10 Top Cover, Removing Screw in Battery Compartment: step 3, image 2 of 2
    • Locate the next screw by holding the camera upside down with the battery compartment empty and face up.
    • Remove the 6.3 mm screw using a J0 screwdriver.
  4. Disassembling Pentax PZ-10 Top Cover, Removing Screw Under Flash Bulb: step 4, image 1 of 2 Disassembling Pentax PZ-10 Top Cover, Removing Screw Under Flash Bulb: step 4, image 2 of 2
    • The next screw is found in the overhanging piece just above the lens.
    • With the top of the camera facing down, remove the 3.4 mm screw with a J0 screwdriver.
  5. Disassembling Pentax PZ-10 Top Cover, Pulling Off the Top Cover: step 5, image 1 of 2 Disassembling Pentax PZ-10 Top Cover, Pulling Off the Top Cover: step 5, image 2 of 2
    • Gently pull off the top cover with your hands by pulling on the tab on the left of the camera.
2 other people completed this guide.
Jonathan Diaz
213 Reputation
2 Guides authored
One Comment
Thank you! Well done sir!
michaelsteele1953 - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 7
All Time: 961
