Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
  1. Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove. Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
    • Remove the 2 exposed screws on opposite sides of the camera. Turn the screws counter-clockwise to remove.
  2. Open the battery compartment and remove the 2 screws in the top of the opening. Open the battery compartment and remove the 2 screws in the top of the opening.
    • Open the battery compartment and remove the 2 screws in the top of the opening.
  3. Remove the 2 exposed screws on the bottom of the camera. Remove the 2 exposed screws on the bottom of the camera.
    • Remove the 2 exposed screws on the bottom of the camera.
  4. Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
    • Uncover the mini-usb dock on the side of the camera and unscrew the screw next to the flap joint
  5. Uncover the video cable port on the side of the camera and remove the screw
    • Uncover the video cable port on the side of the camera and remove the screw
  6. Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera. Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
    • Carefully slip the head of the plastic opening tool under the panels by finding the crack between the panels. Lightly apply pressure in the shown places at the top and bottom of the camera.
  7. Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure. Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
    • Loosen the panels on the sides of the camera in the shown places by slipping the plastic opening tool in the crack between the panels. Lightly apply pressure.
  8. Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels. Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
    • Ensure that the panels have been loosened. Carefully use hands to pull back and remove the panels.
CCrane
201 Reputation
2 Guides authored
Baylor, Team 6-4, Shaver Spring 2015 Member of Baylor, Team 6-4, Shaver Spring 2015
BU-SHAVER-S15S6G4
3 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 171
