Disassembling Microsoft Surface 3 Casing
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Disassembling Microsoft Surface 3 Casing, Casing: step 1, image 1 of 2 Disassembling Microsoft Surface 3 Casing, Casing: step 1, image 2 of 2
    • Warm up an iOpener following the instructions found in the iOpener guide.
    • Place the warm iOpener on top of the edges of the screen. This heat will weaken the strength of the adhesive between the display and body.
  2. Disassembling Microsoft Surface 3 Casing: step 2, image 1 of 2 Disassembling Microsoft Surface 3 Casing: step 2, image 2 of 2
    • Use iFixit opening picks to wedge under the edge of the screen at the speaker port.
    • This may take significant force. A fingernail might work better for the initial lift
    • If you push straight down near the edge you will go through the speaker mesh and possibly end up damaging your speaker; try to push the pick in at a shallow angle.
  3. Disassembling Microsoft Surface 3 Casing: step 3, image 1 of 2 Disassembling Microsoft Surface 3 Casing: step 3, image 2 of 2
    • Carefully try to work your way around the device using the picks, reapplications of the heated iOpener, and luck.
    • If you break the glass on one side you might want to try again starting from the other side so that you have a clean, unbroken, edge on that side.
    • While the glass on this display is not particularly sharp when broken, it is still broken glass and you should be careful with it.
  4. Disassembling Microsoft Surface 3 Casing: step 4, image 1 of 1
    • Flip the display over so that parts underneath it are easily accessible.
    • Do not pull out the display as it is still attached to the motherboard.
    • If you are replacing the display, or want it out of the way, continue with the display replacement guide steps.
Harold Hall
1,329 Reputation
3 Guides authored
Cal Poly, Team 5-12, Maness Fall 2015 Member of Cal Poly, Team 5-12, Maness Fall 2015
CPSU-MANESS-F15S5G12
4 Members
22 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 176
