Disassembling Kodak Easyshare C813 Back Cover
  1. Disassembling Kodak Easyshare C813 Back Cover, Battery: step 1, image 1 of 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Disassembling Kodak Easyshare C813 Back Cover: step 2, image 1 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 2, image 2 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 2, image 3 of 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Disassembling Kodak Easyshare C813 Back Cover, Back Cover: step 3, image 1 of 1
    • Before removing back cover, it is advisable to use an anti-static wrist strap to prevent damage to electronics.
  4. Disassembling Kodak Easyshare C813 Back Cover: step 4, image 1 of 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Disassembling Kodak Easyshare C813 Back Cover: step 5, image 1 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 5, image 2 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 5, image 3 of 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Disassembling Kodak Easyshare C813 Back Cover: step 6, image 1 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 6, image 2 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 6, image 3 of 3
    Tool used on this step:
    Phillips #00 Screwdriver
    $5.49
    Buy
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Disassembling Kodak Easyshare C813 Back Cover: step 7, image 1 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 7, image 2 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 7, image 3 of 3
    • Use PX 3688 wedge(iPod opening tools)to slightly open the side of the case.
    • Insert wedge PX 3688 (iPod opening tools) and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Disassembling Kodak Easyshare C813 Back Cover: step 8, image 1 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 8, image 2 of 3 Disassembling Kodak Easyshare C813 Back Cover: step 8, image 3 of 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the wedge (iPod opening tools) to separate any sides still closely connected.
Susan Marano
336 Reputation
7 Guides authored
Cal Poly, Team 24-22, Regan Spring 2010 Member of Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Members
20 Guides authored
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 5
All Time: 2,366
