You're viewing a previously published version of this guide.  View latest version
Older Newer
  1. Turn off the camera.
    • Turn off the camera.
    • Locate the power switch on the front of the camera below the camera lens.
    • Slide the switch to the off position.
  2. Locate the 3 screws that hold the back cover to the camera. One screw is located on the film opener side of the camera.
    • Locate the 3 screws that hold the back cover to the camera.
    • One screw is located on the film opener side of the camera.
    • The other screws are located on the opposite side of the camera.
  3. Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover. Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover. Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
    • Use the Phillips #00 Precision Screwdriver and remove the screws on the back cover.
  4. Open the film door to remove the back cover. Slide the film door lever to the left until the film door opens.
    • Open the film door to remove the back cover.
    • Slide the film door lever to the left until the film door opens.
  5. Use a plastic opening tool to pry the case open until a small gap is present. Repeat this process at the top and bottom of the film door to loosen it.
    • Use a plastic opening tool to pry the case open until a small gap is present.
    • Repeat this process at the top and bottom of the film door to loosen it.
  6. Grab the top and bottom of the case firmly as shown. Gently remove the back of the camera case with a slight twisting motion. Gently remove the back of the camera case with a slight twisting motion.
    • Grab the top and bottom of the case firmly as shown.
    • Gently remove the back of the camera case with a slight twisting motion.
David Cottrell
58 Reputation
5 Guides authored
UW Stout, Team 1-2, Zhou Fall 2011 Member of UW Stout, Team 1-2, Zhou Fall 2011
UWSTOUT-ZHOU-F11S1G2
4 Members
5 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 5
All Time: 463
