Introduction
This is a guide to remove the top panel of your HP Photosmart c3180 printer.
In order to reduce the risk of injury, please make sure to unplug the printer before disassembly of the top panel.
Rotate the printer 90 degrees counter clockwise so that the side panel next to control panel is facing you.
Remove the two T10 12mm Torx screws from the left side panel.
Rotate the printer 90 degrees counter clockwise.
Inside the printer is a small white tab. Press it inward with a spudger until a pop is heard.
Remove the front panel by grasping its front and pulling away from the printer.
11 other people completed this guide.
