Disassembling HP Mini 110-1046NR Memory Card Cover
Prerequisite Only
This guide is only intended to be used as a prerequisite for other guides. It's incomplete by itself.
  1. Disassembling HP Mini 110-1046NR Memory Card Cover, Battery: step 1, image 1 of 3 Disassembling HP Mini 110-1046NR Memory Card Cover, Battery: step 1, image 2 of 3 Disassembling HP Mini 110-1046NR Memory Card Cover, Battery: step 1, image 3 of 3
    • Power-off the netbook fully before attempting to remove the battery.
    • Flip your netbook upside down, and locate the sliding tabs near the battery.
    • Slide both tabs inward so that the battery visibly moves away from the case of the computer.
    • Release the tabs and pull the battery out.
  2. Disassembling HP Mini 110-1046NR Memory Card Cover, Memory Card Cover: step 2, image 1 of 3 Disassembling HP Mini 110-1046NR Memory Card Cover, Memory Card Cover: step 2, image 2 of 3 Disassembling HP Mini 110-1046NR Memory Card Cover, Memory Card Cover: step 2, image 3 of 3
    • Flip the netbook over so you are looking at the bottom, and locate the two screws that hold the memory card cover.
    • Next, take a Phillips PH1 screwdriver and unscrew the two screws.
    • These screws will not release from the cover once they are unscrewed.
    • If necessary, use the flat end of the spudger to assist in prying the cover away from the computer.
Jared Cooper
649 Reputation
5 Guides authored
Clemson, Team 14-1, Benson Fall 2013 Member of Clemson, Team 14-1, Benson Fall 2013
CLEM-BENSON-F13S14G1
3 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 55
