Introduction
A step-by-step guide to removing the outer case of the Garmin Nuvi 680.
Flip open the antenna on the back of the device.
Remove the two screws on the antenna cover using a T5 Torx screwdriver.
These screws are 4.42 mm long.
Insert the pointed end of a spudger into the leftmost slit of the antenna case.
Push the spudger to the right.
Slide the antenna case out of the device.
Remove the two screws on the back of the outer case using a T5 Torx screwdriver.
These screws are 10.82 mm long.
Starting along the top, separate the front and back of the device by pushing an iPod-opening tool into the crack along each side of the case.
