Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel
Views: 6.8K
View statistics:
Past 24 Hours:
22
Past 7 Days:
167
Past 30 Days:
661
All Time:
6,750
Comments: 3
3 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This is a very nice Keyboard, but after about a year the Volume-Wheel - which i really like overall - started acting up (volume 'jumping' wildly at the slightest touch, sometimes even in the wrong direction)
This guide shows the disassembly of the keyboard to get you close enough into the volume wheel to clean the encoder with some contact cleaner
Tools
    1. Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel, remove Keycaps and screws beneath: step 1, image 1 of 2 Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel, remove Keycaps and screws beneath: step 1, image 2 of 2
      • Most of the screws keeping the whole thing together are between the keys, spread over the whole keyboard. Technically you don't need to remove all of them, but it's quick work and i used the opportunity to clean out the huge amount of dirt that collects beneath them. Just pull the Caps straight up - i used the puller that came with the Keyboard
      • Note: no need to remove the 4 media-keys on the top right
      • Remove the Twenty (20) screws using a PH1 screwdriver
      Ask FixBot
    2. Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel, some hidden screws on the bottom: step 2, image 1 of 3 Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel, some hidden screws on the bottom: step 2, image 2 of 3 Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel, some hidden screws on the bottom: step 2, image 3 of 3
      • turn the keyboard around and lift the corners of the rubber pads to get to the screws that are unfortunately hidden there - see pictures for exact screw positions
      • The pads are glued on, but with a pick or similar prying tool, it's easy to lift one side. I feel confident that the original glue still sticks well enough after one or two of these repairs
      • remove all 4 screws (one beneath each rubber pad)
      • During reassembly, i didn't put these back in, because i'm sure i'll do this repair again in future. The Keyboard doesn't feel less sturdy without these
      Ask FixBot
    3. Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel, the insides: step 3, image 1 of 3 Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel, the insides: step 3, image 2 of 3 Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel, the insides: step 3, image 3 of 3
      • the bottom (plastic) half can now be detached from the front (aluminium) frame - a bit of careful prying along the upper edge (side of the USB - connector) might be needed
      • there's one cable connecting the 2 parts - unplug it from the main PCB
      • the wheel assembly is in the top left corner - unplug the short cable connecting it to the main PCB on one side
      • remove 3 black screws (blue circles) and 2 silver screws (red circles)
      • the complete media control assembly can be lifted out now
      • unplug the remaining cable (that's from the encoder we're trying to get to)
      • the big PCB can now be pulled from the wheel assembly
      Ask FixBot
    4. Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel, volume wheel: step 4, image 1 of 2 Disassembling CORSAIR Gaming K70 for cleaning of the volume wheel, volume wheel: step 4, image 2 of 2
      • from the backside of the wheel-housing there are 4 plastic tabs locking the side-cover-arcs on either side of the wheel in place. Unlatch them with a pointy tool and carefully push the covers out towards the front
      • the wheel and the encoder is now pretty accessible - probably well enough to get some contact cleaner to the contacts
      • i went one step further and lifted the wheel out - first the side opposite from the encoder! then the wheel itself can be pulled out from the encoder and the encoder can slide out of the housing
      • Spraying some contact cleaner onto the encoder and turning it completely fixed the issue at least for now - i hope i don't have to do this too often...
      Ask FixBot
4 other people completed this guide.
RisFutile
229 Reputation
1 Guide authored
3 Guide Comments
my k70's volume encoder has some problem now, Can you give me some detail about the encoder? Like the model, width/height/depth and anything more. Can I simply replace it with the TTC golden wheel encoder?
Yin Steve - Reply Share
I didn't take care or a detailed picture of the part itself, as my plan was to only clean it. if you have to take yours apart anyway please share your findings. Mine works fine since i cleaned it (almost a year now), but i'm pretty sure i will take it apart again at some point and then i can add more details here. Unfortunately that's probably gonna be too late for you to be helpful info...
RisFutile - Reply Share
I have found that a quick repair is possible, although I don't know how long it will hold up. Don't disassemble the keyboard - dribble a small amount of switch cleaner down the right hand side of the volume scroll control, run the scroll up and down to clean the contacts, then finally use a compressed gas spray, in the same place, to blow the liquid away.
If that doesn't work then I guess you could follow the much longer disassembly route.
AC Harper - Reply Share
Past 24 Hours: 22
Past 7 Days: 167
Past 30 Days: 661
All Time: 6,750
