Shop the Holiday Gift Guide
This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit
Views: 1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
27
Past 30 Days:
135
All Time:
1,023
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
Community-Contributed Guide
Introduction
Go to step 1 ↓
If the Leica lens has trapped some dirt or grains of dust, it can cause several problems: the lens may not extend smoothly, or there may be shadows or spots on your images. You can try to disassemble the lens and remove any obstructing foreign objects. This repair is complex and requires a lot of patience and a steady hand.
Leica lenses in Panasonic cameras have a similar construction; this guide might also help you with other devices.
Tools
    1. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit, Back Cover: step 1, image 1 of 1
      • Remove the battery and memory card from the device.
      Ask FixBot
    2. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 2, image 1 of 1
      • Remove 4 screws from the right side of the camera.
      • There are two 3.4mm screws at the top.
      • There are two 2.2mm screws at the bottom.
      Ask FixBot
    3. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 3, image 1 of 1
      • Remove the single 3.4mm screw on the left side of the camera.
      Ask FixBot
    4. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 4, image 1 of 1
      • Remove 5 screws from the base of the camera.
      • There are two 2.2mm screws next to the battery compartment.
      • There are three 4mm screws around the tripod mount.
      Ask FixBot
    5. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 5, image 1 of 1
      • Slowly slide the back cover away from the device
      • The back casing is held in place by two ribbon cables. Do not pull the back cover too far from the camera.
      Ask FixBot
    6. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 6, image 1 of 2 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 6, image 2 of 2
      • Detach both ribbon cables using a spudger.
      • Use the tip of the spudger to lift the black clip upward, unlocking the ribbon cable.
      Ask FixBot
    7. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 7, image 1 of 1
      • Remove the back casing from the camera.
      Ask FixBot
    1. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit, button board: step 8, image 1 of 2 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit, button board: step 8, image 2 of 2
      • Use the spudger to remove the ribbon cable connecting the lens casing to the circuit board by lifting up the black clip.
      • Carefully remove the function switch cover. This unit snaps on and off.
      Ask FixBot
    2. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 9, image 1 of 1
      • Carefully unsnap the front logic board from the rear logic board using a spudger.
      Ask FixBot
    3. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 10, image 1 of 2 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 10, image 2 of 2
      • Slide the entire top part of the camera that is attached to the logic board, horizontally away from the camera.
      Ask FixBot
    4. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 11, image 1 of 3 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 11, image 2 of 3 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 11, image 3 of 3
      • This step is only necessary if you want to separate the upper part from the button board.
      • Remove the ribbon cable from the top connection panel by unlocking the black clip with a spudger.
      • This leaves you with the logic board and the top connection panel separate and free from the camera
      Ask FixBot
    1. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit, Camera Lens Assembly: step 12, image 1 of 1
      • Use a spudger to detach the ribbon cable from the circuit board. Lift the black clip up to unlock it as before.
      Ask FixBot
    2. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 13, image 1 of 1
      • Remove the 3 screws holding the lens assembly in place.
      • The two screws on the left are 4.5mm with washers.
      • The single screw on the right is 4mm.
      Ask FixBot
    3. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 14, image 1 of 1
      • Push the lens assembly slightly toward the circuit board, and pull the left side out of the casing first. You will have to wiggle this out gently.
      Ask FixBot
    4. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 15, image 1 of 2 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 15, image 2 of 2
      • Remove the entire assembly out of the casing.
      • The ribbons on the left and bottom of the assembly simply rest on the camera housing.
      Ask FixBot
    1. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit, Disassemble and clean Leica lens unit: step 16, image 1 of 2 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit, Disassemble and clean Leica lens unit: step 16, image 2 of 2
      • Note how the two grounding contacts of the lens unit are hooked into the body.
      • The CCD is secured with three screws. You only need to unscrew it if there is dust on it. Normally, you can leave it screwed in.
      • The motor for the zoom is located on the side. You will need to unscrew it very carefully later.
      • The motor for the focus normally remains screwed in.
      Ask FixBot
    2. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 17, image 1 of 3 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 17, image 2 of 3 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 17, image 3 of 3
      • Remove the four Phillips screws securing the rear cover.
      • Remove the two screws securing the zoom motor. The second screw is hidden underneath the large ribbon cable.
      • Very carefully detach the zoom motor. Watch out for the ribbon cables.
      • Very carefully lift the rear cover and place it slightly elevated next to the lens cover. Release the ribbon cables from their fastenings and ensure that the sensitive ribbon cables are not pulled too tightly.
      • Note how the two narrow ribbon cables are tucked into a pocket in the body of the lens unit.
      Ask FixBot
    3. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 18, image 1 of 2 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 18, image 2 of 2
      • Mark the position of the parts so you can reinsert them in the exact same orientation later.
      • Grasp the outer ring—firmly but carefully—and rotate it a few millimeters clockwise. Metal pins should become visible in the three notches.
      Ask FixBot
    4. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 19, image 1 of 1
      • Now you can push the inner lens assembly out from the back.
      Ask FixBot
    5. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 20, image 1 of 3 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 20, image 2 of 3 Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 20, image 3 of 3
      • Mark the parts again so you can put them back together correctly later.
      • Rotate the silver metal housing with the front lens and the leaf shutter counter-clockwise. It will detach from the inner lens assembly.
      • If the blades are no longer moving easily, you can move the black pin inside next to the lens back and forth using a spudger. The blades will open and close until all the dirt has loosened.
      Ask FixBot
    6. Disassemble and clean the Panasonic Lumix DMC TZ5 Leica lens unit: step 21, image 1 of 1
      Tool used on this step:
      Dust Blower
      $5.99
      Buy
      • The lens unit is largely disassembled. Remove all dust from the lenses and the interior using a lint-free microfiber cloth. Do not blow with your mouth, but instead use a dust blower.
      • The unit can be disassembled further, but most problems should be resolved now. Open and clean the CCD only if absolutely necessary.
      Ask FixBot
Follow the steps in reverse order to reassemble your device. After reassembly, the lens may have trouble focusing. If you are lucky, you can resolve this by turning the device on and off repeatedly; gently tapping it on several sides might also help.
Author
with
VauWeh
347,247 Reputation
320 Guides authored
Repair is War on Entropy Member of Repair is War on Entropy
Community
46 Members
7,118 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 27
Past 30 Days: 135
All Time: 1,023
