Digital2 D2-861G Battery Replacement
  1. Digital2 D2-861G Battery Replacement, Battery: step 1, image 1 of 1
    • Working on your device while powered on may result in electric shock. Make sure to unplug and power down your device before you begin.
    • Place your device on a soft cloth to avoid scratching the screen.
    • Flip your device over so back panel is facing upwards
  2. Digital2 D2-861G Battery Replacement: step 2, image 1 of 2 Digital2 D2-861G Battery Replacement: step 2, image 2 of 2
    • Do not use a lot of force as it can break the clips or the back panel.
    • Insert spudger in the slot below the micro SD card
    • You should hear clips releasing as you pry along the edges.
    • With the spudger tool, run along the edges of the backing undoing 20 plastic clips.
  3. Digital2 D2-861G Battery Replacement: step 3, image 1 of 3 Digital2 D2-861G Battery Replacement: step 3, image 2 of 3 Digital2 D2-861G Battery Replacement: step 3, image 3 of 3
    • Look at the images to locate the black tabs.
    • Carefully remove the tape to avoid damaging the device.
    • Remove ALL the yellow tape securing the gold colored ZIF (Zero insertion force) connector and the battery. Discard or save the tape if you would like.
    • To unclip the connector. Go under the black tab with a spudger or finger nail and simply lift up.
  4. Digital2 D2-861G Battery Replacement: step 4, image 1 of 2 Digital2 D2-861G Battery Replacement: step 4, image 2 of 2
    • Make sure to not bend or puncture the battery when removing it.
    • Locate the bundled cable connector and disconnect it by simply pulling it gently with your hands or using a spudger.
    • Use prying tools to carefully break the adhesive under the battery
One Comment
where do you find the replacement battery?
rsdii - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 924
