DigiLand DL1010Q Battery Replacement
  1. DigiLand DL1010Q Battery Replacement, Rear Case: step 1, image 1 of 1
    • With a J00 Philips head screwdriver, unscrew the two 4mm black screws located at the bottom of the device.
    • Before disassembling your device, be sure it is powered off.
  2. DigiLand DL1010Q Battery Replacement: step 2, image 1 of 2 DigiLand DL1010Q Battery Replacement: step 2, image 2 of 2
    • Using a plastic opening tool, begin softly prying open device by first inserting it in between the front and back panels.
    • Continue prying the edges while moving around the device's perimeter until the back can be easily removed.
  3. DigiLand DL1010Q Battery Replacement: step 3, image 1 of 1
    • Carefully lift back panel away from the body of the device.
    • Speaker wires are connected to both the front and back panel.
  4. DigiLand DL1010Q Battery Replacement, Battery: step 4, image 1 of 2 DigiLand DL1010Q Battery Replacement, Battery: step 4, image 2 of 2
    • Desolder positive and negative, red and black, wires from the mother board that are connected to the battery.
    • The soldering tool is hot, and will burn. For how to use a soldering tool follow the How to Solder Guide
  5. DigiLand DL1010Q Battery Replacement: step 5, image 1 of 2 DigiLand DL1010Q Battery Replacement: step 5, image 2 of 2
    • Using a metal spudger tool, wedge between battery and metal screen.
    • Follow the edge of the battery to loosen the glue.
  6. DigiLand DL1010Q Battery Replacement: step 6, image 1 of 2 DigiLand DL1010Q Battery Replacement: step 6, image 2 of 2
    • Once the glue is loosened, you should be able to pry off the battery from the screen.
    • Using your hands, pull up on the battery to pull battery off.
    • Pulling on the battery causes you to bend the battery. Bending the battery could cause it to break open. Battery fumes are toxic and unsafe.
    • The battery will be completely disconnected and you can set the battery aside in a safe place.
3 Comments
the replacemet has 3 wires .where go the 3 wire?
javier perez - Reply
were can i buy a new  bettery
Theresa - Reply
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 16
All Time: 4,558
