How to diagnose Samsung Galaxy A40 Charging Problems
Video Overview
  1. How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: step 1, image 1 of 3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: step 1, image 2 of 3 How to diagnose Samsung Galaxy A40 Charging Problems, +5V line: step 1, image 3 of 3
    • This is the +5V line from the Charging port to the Motherboard.
  2. How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: step 2, image 1 of 3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: step 2, image 2 of 3 How to diagnose Samsung Galaxy A40 Charging Problems, Back cover removal.: step 2, image 3 of 3
    • Warm the device to soften the adhesive.
    • Use Sanction cup, Plastic tools and isopropyl alcohol.
    • Remove the silver Phillips screws from the device's frame.
  3. How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: step 3, image 1 of 3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: step 3, image 2 of 3 How to diagnose Samsung Galaxy A40 Charging Problems, Fingerprint sensor: step 3, image 3 of 3
    • Remove the plastic cap from the Fingerprint flex cable connector and disconnect the cable.
    • Remove the SIM Tray.
  4. How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: step 4, image 1 of 3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: step 4, image 2 of 3 How to diagnose Samsung Galaxy A40 Charging Problems, Middle frame removal: step 4, image 3 of 3
    • Use a plastic tool to separate the back cover from the frame. Start from the SIM tray hole.
    • Disconnect the battery.
  5. How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: step 5, image 1 of 3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: step 5, image 2 of 3 How to diagnose Samsung Galaxy A40 Charging Problems, Measurement: step 5, image 3 of 3
    • Disconnect the main flex cable and connect the charger.
    • Use a multimeter to measure the voltages at the large end pins of the FPC connector of the charging board. (See the second image)
    • If the reading is okay (~5V) continue with the next step, if not - change the Charging board.
    • Attach the main flex cable and measure the large end pins of the Main flex FPC connector - pic.3.
    • If the reading is okay, continue with the next step, if not - change the Main flex cable.
  6. How to diagnose Samsung Galaxy A40 Charging Problems: step 6, image 1 of 3 How to diagnose Samsung Galaxy A40 Charging Problems: step 6, image 2 of 3 How to diagnose Samsung Galaxy A40 Charging Problems: step 6, image 3 of 3
    • Remove the adhesive rubber around the main flex connector on the logic board.
    • Use some flux and a soldering iron to re-solder the first pin of the motherboard FPC.
4 other people completed this guide.
ZFix
191,182 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
322 Members
2,521 Guides authored
0 Comments
Past 24 Hours: 4
Past 7 Days: 48
Past 30 Days: 206
All Time: 7,933
