This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Dexter 750W Corded Jigsaw Switch Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
64
All Time:
570
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will show you how to replace the switch of a Dexter 750W corded jigsaw.
    1. Dexter 750W Corded Jigsaw Switch Replacement, Unplug: step 1, image 1 of 1
      • Before you begin, remember to unplug the socket.
      Ask FixBot
    2. Dexter 750W Corded Jigsaw Switch Replacement: step 2, image 1 of 1
      • Remove the vacuum adapter from the back of the device.
      Ask FixBot
    3. Dexter 750W Corded Jigsaw Switch Replacement: step 3, image 1 of 2 Dexter 750W Corded Jigsaw Switch Replacement: step 3, image 2 of 2
      • Using a screwdriver or screwdriver, unscrew and open the device.
      • Unlock the tray by lifting the lever.
      Ask FixBot
    4. Dexter 750W Corded Jigsaw Switch Replacement: step 4, image 1 of 1
      • Remove the black screw in order to remove the knob.
      Ask FixBot
      • Using a screwdriver, pry to be able to recover the wheel.
      Ask FixBot
    5. Dexter 750W Corded Jigsaw Switch Replacement: step 6, image 1 of 1
      • Turn over the switch to be able to access the screws.
      Ask FixBot
    6. Dexter 750W Corded Jigsaw Switch Replacement: step 7, image 1 of 1
      • Remove the four screws to be able to unlock the system and remove the wires.
      Ask FixBot
    7. Dexter 750W Corded Jigsaw Switch Replacement: step 8, image 1 of 2 Dexter 750W Corded Jigsaw Switch Replacement: step 8, image 2 of 2
      • Replace the new switch and reseat the wires. Be careful to put each wire back in its place.
      • Following the picture, the red wire is at the top left, the blue wire at the top right, the blue and black wire at the bottom left, and the brown wire at the bottom right.
      • The cables must be placed below so as not to interfere with the closure and must not protrude.
      Ask FixBot
    8. Dexter 750W Corded Jigsaw Switch Replacement: step 9, image 1 of 1
      • Put the wheel back in its housing and screw it back on.
      Ask FixBot
    9. Dexter 750W Corded Jigsaw Switch Replacement: step 10, image 1 of 1
      • Close and screw the device.
      Ask FixBot
follow guide through or in reverse to reassemble
Special thanks to these translators:
fr en
100%
HelloMacOS is helping us fix the world! Want to contribute?
Start translating ›
Céline Chemineau
17,052 Reputation
95 Guides authored
Leroy Merlin Member of Leroy Merlin
Community
39 Members
1,632 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 64
All Time: 570
