Introduction
Hard drives store most of the information on a computer. The hard drive of a computer must be replaced if the computer crashes. Hard drive replacement is an important skill for desktop PC users.
Remove the two Phillips #2 head 5mm screws from the back side of the computer case. You only need to remove the screws that hold down the panel.
Remove two Phillips #2 head 5mm screws from the back side of the computer case.
Next, remove the side panel of the computer case to allow access into the computer.
59 other people completed this guide.
2 Comments
Pour remonter l'installation,
-remonter le disque dur faite le glisser dans la cage métallique
- fixer le disque dur avec les vis retirées
-fixer les câbles à l'arrière du disque( câble d'alimentation et nappe de données)
-mettre les panneaux dans l'ordre du retrait
- procéder à l'installation du système d'exploitation...
This depends on the model of system. Some systems have a lever/latch to pull to release the cover. Many Dell and HP models use latches to open the covers (no tools required to open the system). Some systems need a screwdriver to remove the screws. Some are Phillips screws, others may be Torx.
Dave Ellefson - Reply
This is correct.
DistroHopper39B -
