Introduction
This guide describes how to replace the hard drive for the Dell XPS M1730 M1730.
Turn the computer over, loosen the two captive screws on the hard drive cover, and then remove the cover
Loosen the four captive screws on the hard drive cage and then lift the pull-tab to flip the cage towards the center of the computer so that the SATA cables and connectors are accessible
Carefully remove the SATA cables from the hard drive or drives that are installed in the cage
Remove two screws on each side of the hard drive cage to free the hard drive, then lift the drive out of its tray in the cage
Remove the new hard drive from its packaging. Save the original packaging for storing or shipping the hard drive
Place the new hard drive into the drive cage tray and secure it with two screws on each side.
Install the primary hard drive in the tray labeled 0. You can install a secondary hard drive in the tray labeled 1.
