Dell XPS 15 9575 I/O Board Replacement
    1. Dell XPS 15 9575 I/O Board Replacement, Bottom Cover: step 1, image 1 of 3 Dell XPS 15 9575 I/O Board Replacement, Bottom Cover: step 1, image 2 of 3 Dell XPS 15 9575 I/O Board Replacement, Bottom Cover: step 1, image 3 of 3
      • For your safety, please make sure the device is powered off and the A/C adapter is unplugged.
      • Use your T5 Torx driver to remove all eight 3.2 mm screws holding down the back panel.
      • Wedge an opening pick between the back cover and the base of the board, then slightly lift the tool to pop the clips on the back cover off.
      Ask FixBot
    2. Dell XPS 15 9575 I/O Board Replacement: step 2, image 1 of 1
      • Make sure all screws are removed before you lift the panel to prevent any damage from occurring.
      • Remove the bottom cover from the device when all sides are free.
      Ask FixBot
    1. Dell XPS 15 9575 I/O Board Replacement, Interconnect Cable: step 3, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement, Interconnect Cable: step 3, image 2 of 2
      • Use the Phillips #0 screwdriver to remove all four silver 3.2 mm screws fastening the interconnect cable.
      Ask FixBot
    2. Dell XPS 15 9575 I/O Board Replacement: step 4, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement: step 4, image 2 of 2
      • Carefully wedge the plastic opening pick between the fan and the interconnect cable.
      • If this position does not release the interconnect cable, slide the opening pick along the edge until it is completely free.
      • Remove the interconnect cable.
      Ask FixBot
    3. Dell XPS 15 9575 I/O Board Replacement: step 5, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement: step 5, image 2 of 2
      • Use the nylon tweezers to remove the interconnect pins from each of the circuit boards.
      Ask FixBot
    1. Dell XPS 15 9575 I/O Board Replacement, Battery: step 6, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement, Battery: step 6, image 2 of 2
      • Use the Phillips #0 screwdriver to remove all eight 6.4 mm screws from the battery.
      Ask FixBot
    2. Dell XPS 15 9575 I/O Board Replacement: step 7, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement: step 7, image 2 of 2
      • Use a plastic opening pick to pry the black battery cable away from its silver adapter.
      • Hold the pick at 35 degrees from the computer and push towards the battery to remove the cable from its socket.
      • Do not push straight into the battery cable as this could damage the adapter.
      • When you disconnect connectors like these, be careful not to dislodge the small surface-mounted components surrounding the socket.
      Ask FixBot
    3. Dell XPS 15 9575 I/O Board Replacement: step 8, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement: step 8, image 2 of 2
      • Use a plastic opening pick to separate the battery from the device.
      • Lift the battery straight up and remove it when it is completely separated.
      Ask FixBot
    1. Dell XPS 15 9575 I/O Board Replacement, Fan: step 9, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement, Fan: step 9, image 2 of 2
      • Use the Phillips 0 Screwdriver to carefully extract each of the four 3.2 mm screws.
      Ask FixBot
    2. Dell XPS 15 9575 I/O Board Replacement: step 10, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement: step 10, image 2 of 2
      • Confirm all four screws have been extracted from the fan.
      • Find the wire connecting the fan into the motherboard and use the plastic opening tool to push the wire out from the motherboard's port.
      Ask FixBot
    3. Dell XPS 15 9575 I/O Board Replacement: step 11, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement: step 11, image 2 of 2
      • The fan has been completely disconnected and is now safe to remove.
      Ask FixBot
    1. Dell XPS 15 9575 I/O Board Replacement, I/O Board: step 12, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement, I/O Board: step 12, image 2 of 2
      • Use a spudger or a clean fingernail to flip up the locking flap of the ZIF connector.
      • Use tweezers or your fingers to gently pull the orange cable out of its socket on the I/O board.
      • If the cable has a pull tab, use it to grip the cable. You may damage the cable by gripping it directly.
      • To reconnect, make sure the locking flap is flipped up and gently reinsert the cable. Then, flip the locking flap down to secure the cable. The cable should slide into the socket with little to no force. If you're having trouble, remove it, check that the flap is fully unlocked, and try again.
      Ask FixBot
    2. Dell XPS 15 9575 I/O Board Replacement: step 13, image 1 of 3 Dell XPS 15 9575 I/O Board Replacement: step 13, image 2 of 3 Dell XPS 15 9575 I/O Board Replacement: step 13, image 3 of 3
      • Use a Phillips #0 screwdriver to remove the six 3.2 mm screws securing the I/O board.
      • Use the tweezers to remove the silver bracket covering the coaxial cable connectors.
      Ask FixBot
    3. Dell XPS 15 9575 I/O Board Replacement: step 14, image 1 of 3 Dell XPS 15 9575 I/O Board Replacement: step 14, image 2 of 3 Dell XPS 15 9575 I/O Board Replacement: step 14, image 3 of 3
      • Use the point of a spudger to push on alternating sides of the connector to "walk" it out of its socket and disconnect the speaker cable from the I/O board (also known as the daughterboard).
      • It may take a lot of alternating before the connector comes out. Be patient, and don't pull on the cables.
      • To reconnect the cable, align the connector and use a spudger or clean fingernail to push it fully into the socket.
      • Don't push on the cables themselves, or you may damage the connector.
      Ask FixBot
    4. Dell XPS 15 9575 I/O Board Replacement: step 15, image 1 of 2 Dell XPS 15 9575 I/O Board Replacement: step 15, image 2 of 2
      • To disconnect the black and white coaxial cables, slide a thin, ESD-safe pry tool or angled tweezers under the metal neck of the connector (as close to the head as possible) and lift straight up from the board.
      • When working with these connectors, it's key to always lift the head straight up. If pried on at an odd angle, you risk breaking the socket off of the board underneath.
      • Reconnecting these can be tricky. Use tweezers to hold the connector in place over its socket and gently press down with your finger or a spudger—the connector should "snap" into place. If you're having trouble, reposition the head and try again.
      • Don't try to force the connector into place or you may permanently damage it.
      Ask FixBot
    5. Dell XPS 15 9575 I/O Board Replacement: step 16, image 1 of 1
      • Slide the I/O board away from the edge of the laptop towards the inside of the device to release it.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 79
All Time: 694
