Introduction
This guide will walk you through the process of replacing the speakers in your Dell XPS 15 9570. If you are experiencing distorted sound, no sound output, or a blown-out speaker, this guide will help restore your laptop’s audio functionality.
During the replacement process, take precautions to avoid electrostatic discharge by using an ESD-safe tool or working on an anti-static mat.
Advanced technical skills are not required to replace the speakers.
Before you begin, make sure that your device is off and disconnected from the charger.
Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
Using the Phillips #00 screwdriver, remove the four 4 mm screws holding the battery in place.
Remove the speakers from the back of the computer.
Replace speakers with Dell 6GTPY 91 Wh Battery.
