Dell XPS 15 9570 SSD Replacement
  1. Dell XPS 15 9570 SSD Replacement, Base Cover: step 1, image 1 of 1
    • Make sure your device is powered off and unplugged before starting
    • Flip the device over so the base cover of the computer is facing upwards.
  2. Dell XPS 15 9570 SSD Replacement: step 2, image 1 of 3 Dell XPS 15 9570 SSD Replacement: step 2, image 2 of 3 Dell XPS 15 9570 SSD Replacement: step 2, image 3 of 3
    • Using a Torx T5 screwdriver, remove the ten 3 mm screws on the back.
  3. Dell XPS 15 9570 SSD Replacement: step 3, image 1 of 2 Dell XPS 15 9570 SSD Replacement: step 3, image 2 of 2
    • Flip open the system badge and with a Phillips #00 screwdriver, remove the two 8.5 mm screws.
  4. Dell XPS 15 9570 SSD Replacement: step 4, image 1 of 1
    • Lift the back cover off of the device.
  5. Dell XPS 15 9570 SSD Replacement, SSD: step 5, image 1 of 2 Dell XPS 15 9570 SSD Replacement, SSD: step 5, image 2 of 2
    • Use the Phillips #00 screwdriver to remove the 5.5 mm screw next to the SSD.
  6. Dell XPS 15 9570 SSD Replacement: step 6, image 1 of 2 Dell XPS 15 9570 SSD Replacement: step 6, image 2 of 2
    • Using your hands, hold the SSD and slightly pull to the left.
Baidullah Hazrat
85 Reputation
1 Guide authored
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 60
All Time: 2,167
