Introduction
The cooling fans help keep the laptop from over heating. If your laptop seems especially hot or loud, it could be caused by a faulty fan or two.
Parts
No parts specified.
Turn the laptop upside down.
Using a T5 Torx Screwdriver, remove the ten 3 mm long screws from the perimeter of the back of the laptop.
Open up the information panel door (on the middle of the back side).
While holding the door open, use a Phillips #00 Screwdriver to remove the two 10 mm long screws.
Using the Small Plastic Spudger, carefully disconnect the white connector from the black port.
7 other people completed this guide.
2 Comments
I removed the fans for cleaning the dust. Now the left fan is always at 100%. Can anybody help me with that problem? Is it possible to somehow misconnect the fan? Or did I accidently did something to the temperature sensors?
DId you manage to fix the problem? I have the same issue with the right fan.
