  1. Remove eight T5 Torx screws Remove a Philips screw under the plastic tab Remove a Philips screw under the plastic tab
    • Remove eight T5 Torx screws
    • Remove a Philips screw under the plastic tab
  2. Use opening picks to open the lower case Use opening picks to open the lower case
    • Use opening picks to open the lower case
  3. MacBook Battery Fix Kits
    Starting at $69.99
    Buy Now
    Starting at $69.99
    Buy Now
  4. Disconnect the battery and move the battery cable out of the way Disconnect the battery and move the battery cable out of the way
    • Disconnect the battery and move the battery cable out of the way
  5. Remove a Philips screw Use a pair of tweezers to remove a metal clamp holding the wireless card Use a spudger to disconnect a couple of antenna cables
    • Use a pair of tweezers to remove a metal clamp holding the wireless card
    • Use a spudger to disconnect a couple of antenna cables
    • Pull the wireless card parallel to the motherboard
    • Do not lift the wireless card upward or risk damaging the wireless card slot
10 other people completed this guide.
The Raptor
4,249 Reputation
7 Guides authored
3 Comments
Removing it, all well and good, and don’t get me wrong, helpful. But what about installing the replacement, and especially what tools and how to reconnect the wireless card antenna cables.?
Steven Thibault - Reply
Taking the card is all well and good, and don’t get me wrong, this is helpful for that, but what about the other half, installing the replacement. Especially how to reconnect the wireless cards antenna cables and the tools necessary for that?
This article is incomplete. And it doesn’t address how easy it is to damage the wires connected to the wireless card.
Matthew Coburn - Reply
Past 24 Hours: 3
Past 7 Days: 43
Past 30 Days: 209
All Time: 7,545
