Introduction
Use this guide to replace the Wireless Network Interface Cards (NIC) in your Dell XPS 13 9350.
  1. Remove the eight 4 mm T5 Torx screws from the bottom cover. Remove the eight 4 mm T5 Torx screws from the bottom cover.
    • Remove the eight 4 mm T5 Torx screws from the bottom cover.
  2. Lift up the back cover using both hands.
    • Lift up the back cover using both hands.
  3. Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
    Browse Our Store
  4. Use tweezers to remove the white and black connectors by pulling them away from the Wi-Fi card.
    • Use tweezers to remove the white and black connectors by pulling them away from the Wi-Fi card.
    • Grab the connectors gently from the bottom of the metal heads.
  5. Remove the 3 mm Phillips #0  screw that secures the Wi-Fi card in place. The Wi-Fi card will pop up at a 45-degree angle once the screw is removed.
    • Remove the 3 mm Phillips #0 screw that secures the Wi-Fi card in place.
    • The Wi-Fi card will pop up at a 45-degree angle once the screw is removed.
  6. Use your hand to gently remove the Wi-Fi card by pulling it up and away from its base.
    • Use your hand to gently remove the Wi-Fi card by pulling it up and away from its base.
3 other people completed this guide.
Jay
261 Reputation
2 Guides authored
Cal Poly, Team S21-G6, Livingston Spring 2017 Member of Cal Poly, Team S21-G6, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G6
5 Members
14 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 66
All Time: 1,047
