Fix Your Stuff
Right to Repair
Parts & Tools
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
In this guide, we will show you how to remove and replace the Optical Drive.
Parts
No parts specified.
  1. Slide the left and the right battery release latches to the unlock position.
    • Slide the left and the right battery release latches to the unlock position.
  2. Slide the battery and remove it from the computer.
    • Slide the battery and remove it from the computer.
  3. Loosen the screw that secures the memory door.
    • Loosen the screw that secures the memory door.
  4. Nintendo Switch Kits
    A quick fix to get back in the game
    Shop Switch Kits
    Shop Switch Kits
  5. Pry up the memory door near the screw hole, lift and remove it.
    • Pry up the memory door near the screw hole, lift and remove it.
    • If this is all you are doing Follow Step In Reverse if not Go to Next Step.
  6. Remove the screw that secures the optical drive to the computer.
    • Remove the screw that secures the optical drive to the computer.
  7. Gently pry the optical drive out of the computer.
    • Gently pry the optical drive out of the computer.
  8. Remove the screws that secure the optical drive bracket.
    • Remove the screws that secure the optical drive bracket.
  9. Remove the optical drive bracket from the optical drive module.
    • Remove the optical drive bracket from the optical drive module.
Johnathan Hammond
36,995 Reputation
408 Guides authored
Informative Technologies Inc. Member of Informative Technologies Inc.
Community
21 Members
1,816 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 3
All Time: 76
