Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓The rear camera assembly in the Dell Venue Pro is mounted on a separate board inside the device. To access and replace the rear camera, the phone must be opened and the motherboard fully exposed.
This guide shows how to safely remove and replace the rear camera assembly.
Tools
Remove Back Cover
Remove the back cover using the instructions in the Dell Venue Pro Back Cover Removal guide.
Lift the battery from the top edge and set it aside.
Disconnect Ribbon Cables
At this point, the motherboard should be fully visible, as shown in your reference photos. You should see:
Disconnect the following cables:
Display cable
Metal shielding in the center
Micro-USB charging port at the bottom
Secondary daughterboard connection on the left side
After reassembly, power on the phone and test the rear camera to confirm it focuses and captures images correctly.
