Shop the Holiday Gift Guide
Dell Venue Pro Motherboard Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
22
Past 30 Days:
79
All Time:
355
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 30 - 40 minutes
Difficulty: Difficult
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Confusing Text
Some of this guide's text is confusing, duplicated, or off-topic. Clarify it by editing!
Markup Mishap
This guide needs better markups. Help out by correcting or making some markup annotations.
Introduction
Go to step 1 ↓
Use this guide to replace the motherboard in the Dell Venue Pro.
A damaged or malfunctioning charging port is a common reason for motherboard replacement, since the charging port is integrated into the main logic board.
This is an advanced repair that requires removing several internal components. Before beginning, power off your device and remove the back cover and battery.
Tools
    1. Dell Venue Pro Motherboard Replacement, Back Cover: step 1, image 1 of 1
      • Slide the back cover up.
      • Lift the back cover away from the device completely.
      Ask FixBot
    1. Dell Venue Pro Motherboard Replacement, Battery: step 2, image 1 of 2 Dell Venue Pro Motherboard Replacement, Battery: step 2, image 2 of 2
      • Use your finger to lift the battery using the notch in the upper left corner of the compartment.
      Ask FixBot
    1. Dell Venue Pro Motherboard Replacement, Motherboard: step 3, image 1 of 2 Dell Venue Pro Motherboard Replacement, Motherboard: step 3, image 2 of 2
      • Use a Phillips #00 screwdriver to remove the 4.6 mm screws securing the midframe to the phone.
      Ask FixBot
    2. Dell Venue Pro Motherboard Replacement: step 4, image 1 of 2 Dell Venue Pro Motherboard Replacement: step 4, image 2 of 2
      • Insert a plastic opening tool into the seam between the midframe and the phone body.
      • Gently twist the tool to release the clips around the edges.
      • Once all clips have disengaged, lift the midframe away from the phone and set it aside.
      • If the midframe resists, continue sliding the tool along the seam until all clips release.
      Ask FixBot
    3. Dell Venue Pro Motherboard Replacement: step 5, image 1 of 2 Dell Venue Pro Motherboard Replacement: step 5, image 2 of 2
      • Expose the Motherboard
      • With the midframe removed, the motherboard should now be fully visible.
      • Identify the following components before continuing:
      • SIM card reader near the top of the device
      • Metal shielding covering the center of the motherboard
      • Micro-USB charging port at the bottom
      • Secondary daughterboard connection on the left side
      • Set the midframe aside.
      Ask FixBot
    4. Dell Venue Pro Motherboard Replacement: step 6, image 1 of 3 Dell Venue Pro Motherboard Replacement: step 6, image 2 of 3 Dell Venue Pro Motherboard Replacement: step 6, image 3 of 3
      • Disconnect Ribbon Cables
      • At this point, the motherboard should be fully visible, as shown in your reference photos. You should see:
      • Use tweezers or a fingernail to gently lift the flex cable connectors straight up from their sockets. Disconnect the following cables:
      • Display cable
      • Any remaining flex cables attached to the motherboard
      • Do not pull on the cables themselves. Always lift from the connector.
      Ask FixBot
    5. Dell Venue Pro Motherboard Replacement: step 7, image 1 of 2 Dell Venue Pro Motherboard Replacement: step 7, image 2 of 2
      • Remove the Motherboard Screws
      • Use a Phillips #00 screwdriver to remove the 2.68 mm screws securing the motherboard to the frame.
      • Screws are located near:
      • The bottom right corner (charging port area)
      • The middle left side
      • The top of the motherboard
      • Set all screws aside.
      • Using longer screws in motherboard locations can cause permanent damage.
      Ask FixBot
    6. Dell Venue Pro Motherboard Replacement: step 8, image 1 of 3 Dell Venue Pro Motherboard Replacement: step 8, image 2 of 3 Dell Venue Pro Motherboard Replacement: step 8, image 3 of 3
      • Starting from the top edge, gently lift the motherboard up and away from the phone housing.
      • The micro-USB charging port may fit snugly in its opening. Lift carefully to avoid bending the board.
      • Once free, remove the motherboard from the device.
      • Do not flex or twist the motherboard during removal.
      Ask FixBot
After reassembly, power on the device and confirm that it boots normally.
Plug in a charger to verify that the charging port functions correctly and that the device charges as expected.
Author
with
Todjay A Orr
719 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 22
Past 30 Days: 79
All Time: 355
