Dell Venue 8 Rear Case/Midframe Replacement
  1. Dell Venue 8 Rear Case/Midframe Replacement, Rear Case/Midframe: step 1, image 1 of 1
    • Hold the device with the screen facing up. Gently wedge your plastic opening tool into the crease, and run it along the perimeter of the case
    • You will hear click sounds as the clips unhinge
    • Remove the back panel of the device.
  2. Dell Venue 8 Rear Case/Midframe Replacement: step 2, image 1 of 3 Dell Venue 8 Rear Case/Midframe Replacement: step 2, image 2 of 3 Dell Venue 8 Rear Case/Midframe Replacement: step 2, image 3 of 3
    • Remove the 14 screws with the T-5 Torx screwdriver. (11 black 3.6mm screws, and three 4.45mm screws)
    • 4.45mm Silver screws
    • 3.6mm Black screws
    • Gently snap the perimeter clips open, and remove the internal plastic case.
Andrea
1,071 Reputation
5 Guides authored
USF Tampa, Team 9-2, Leahy Winter 2015 Member of USF Tampa, Team 9-2, Leahy Winter 2015
USFT-LEAHY-W15S9G2
3 Members
12 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 2
All Time: 2,434
