Dell VRC100-R Battery Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
Past 7 Days:
8
Past 30 Days:
59
All Time:
1,325
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
If your controller does not turn on, you've come to the right place. This guide will walk you through how to replace your controller's batteries. You do not need any special tools.
    1. Dell VRC100-R Battery Replacement, Battery: step 1, image 1 of 3 Dell VRC100-R Battery Replacement, Battery: step 1, image 2 of 3 Dell VRC100-R Battery Replacement, Battery: step 1, image 3 of 3
      • Orient your controller so that the black ring is on the bottom and the buttons are facing away from yourself.
      • Place your thumb on the small arrow that is on the controller's battery cover and firmly push upwards.
      • Slide the cover off and separate it from the controller.
      Ask FixBot
    2. Dell VRC100-R Battery Replacement: step 2, image 1 of 2 Dell VRC100-R Battery Replacement: step 2, image 2 of 2
      • Remove the right battery by pushing the positive end down and pulling the battery out toward yourself.
      • Repeat the procedure for the left battery.
      Ask FixBot
Kenneth Liu
169 Reputation
2 Guides authored
Cal Poly, Team S18-G3, Livingston Spring 2018 Member of Cal Poly, Team S18-G3, Livingston Spring 2018
CPSU-LIVINGSTON-S18S18G3
4 Members
60 Guides authored
1 Guide Comment
Hi,
I will like to know if using 1.2V ni-mh rechargeable batteries will affect the performance of the device, as it’s been a debate for long and will appreciate your technical point of view.
Many thanks.
Baba Nam Kevalam - Reply Share
Past 24 Hours: 1
Past 7 Days: 8
Past 30 Days: 59
All Time: 1,325
